[下载] HSMWorks 2012 R4.31141 for SolidWorks 2007-2013
查看: 1141|回复: 0
  • 签到天数: 75 天
    发表于 2015-5-5 14:00:30 | 显示全部楼层 |阅读模式
    HSMWorks2012 R4.31141 for solidworks 2007-2013
    HSMWorks2012 R4.31141 for SolidWorks 2007-2013 | 386.3 mb
    HSMWorks is designed from the ground up to work inside SolidWorks, and built ona modern software architecture, providing a logical extension of the parametricSolidWorks assembly environment into the CAM world.
    Our total focus and commitment to SolidWorks allows us to provide the best CAMexperience inside SolidWorks. Experienced SolidWorks users feel right at homeworking with HSMWorks and will be able to create high-quality toolpaths withinminutes. New users benefit from the unmatched 2D and 3D CAD capabilities ofSolidWorks mechanical design solutions and quickly extend any knowledge gainedto the CAM process, resulting in improved design quality and reduced productdevelopment time.
    New in this version: HSMWorks 2012 R4 Build 31141
    About HSMWorks
    HSMWorks ApS develops and markets CAD/CAM software for all industries fromautomotive and aerospace to consumer products and transportation. Our primaryproduct is HSMWorks, a fully integrated CAM solution for SolidWorks.
    The team behind HSMWorks has been delivering advanced CNC toolpath technologyto customers worldwide for the past 15 years through 3rd party CAM vendors andresellers. However, due to constraints in architecture and user interface,existing CAM systems were unable to take full advantage of our advancedtoolpath technology, HSMWorks was founded in 2007 to market and develop thenext generation CAM system, designed from the ground up to be capable ofbringing all the benefits of our technology to the end-user.
    Headquartered in Copenhagen Denmark, HSMWorks ApS employs a dedicated team ofworld-class developers and an experienced team of sales and marketingprofessionals in Denmark, the UK and the United States.
    Version: 2012 R4 Build 31141 for SolidWorks 2007-2012
    Home: www.hsmworks.com
    Interface: multilanguage
    OS: Windows XP / Vista / Seven
    System requirements: SolidWorks 2007-2012
    HSMWorks從設計之初到SolidWorks內工作,提供了參數化的SolidWorks裝配環境的一個合乎邏輯的延伸到世界的CAM。有經驗的SolidWorks用戶會感到賓至如歸與HSMWorks工作,就能在幾分鐘內創建高質量的刀具路徑。新的用戶將受益於全面的2D和SolidWorks機械設計解決方案的3D CAD功能並迅速擴展任何知識積累到CAM過程,從而提高設計質量,減少產品開發時間。
    HSMWorks直接集成到的SolidWorks®3D設計軟件
    提供的CAD和CAM單一的用戶界面。
    同類最佳刀具路
    HSMWorks被設計以產生平滑的刀具路徑可能從而減少加工時間,提高了表面質量,較少工具的磨損和延長機器的刀具壽命。HSMWorks具有創新的刀具路徑策略,像自適應結算,即通常由4個或更多的係數相對於傳統的粗加工減少粗加工時間,和由多達增加工具壽命的10視材料硬度的一個因素。
    HSMWorks包括所有的傳統加工策略,包括並行,輪廓,口袋,扇貝,徑向,螺旋和鉛筆最熟悉的CAM用戶。HSMWorks通過生成平滑連接動作,縮短加工時間,提高了刀具和機床刀具壽命將這些策略進一步。
    HSMWorks採用了最新的技術,包括對64位版本造成性能優越的SolidWorks用戶的原生64位支持,在大型或複雜的設計工作時尤其如此。
    HSMWorks旨在利用最新的工作站技術,包括4的優勢 - 24核系統。多處理器/多核支持大大加快生成複雜的刀具軌跡生成和不僅在多個操作或設計變更後的重建複雜的零件,而且還產生一個單一的刀具路徑時是有益的。
    用戶可以繼續在SolidWorks中工作時,刀具路徑計算的背景下,由於HSMWorks“高級任務管理器功能。
    分佈式CAM
    分佈式CAM服務器HSMWorks使用戶能夠響應更快設計變更,通過自動利用本地網絡上的閒置電腦減少刀具路徑的計算時間。分佈式CAM自動被HSMWorks當選擇電腦安裝,不需要額外的設置或互動從用戶使用。
    百度云链接.rar (173 Bytes, 下载次数: 11)
