808 car keys micro-camera
查看: 252|回复: 0
发表于 2014-7-31 00:20:13 | 显示全部楼层 |阅读模式
欢迎选购联系电话13410600851 QQ2897873955
如有需要的话,可以向我们索要图片和价格 谢谢!非诚勿扰! qq空间也有图片哦
Description This is another car key sized spy camera. It can take photo with high resolution 1280*960 and record video with resolution 640*480. Its simple design makes it easily operated, while its smart shape makes it portable with owner. With 4GB storage built in, it can also be used as a flash disk. Specification:
Main Function: Video recording "Spy Device" and USB drive with 4 GB's of memory
Device Specifications:
Color CMOS sensor
Auto White Balance Adjustment
Focus Range: 150mm ~ Infinity
Internal Flash Memory: 4GB
Digital Still Camera Specifications:
Format: JPEG Image Resolution: 1280x960 (1.2MP)
Digital Video Recorder Specifications:
Format: AVI
Frame Rate: 30 FPS
Capture Resolution: 640x480 (VGA)
Power Source: Internal Rechargeable 280 mAh Battery
Maximum Recording Time: 60-90 minutes
Dimensions (mm): 50 (L) x 32 (W) x13 (H)
