概况 BD 系列静液传动单元 .................................................................................................................................5
BDU-10 S,原理图 ........................................................................................................................................6
BDU-21 L,原理图.........................................................................................................................................7
系统示意图, BDU-06/10S ............................................................................................................................8
系统示意图, BDU-10L/21L/21H ................................................................................................................9
系统示意图, BDU-10L/21L/21H, BDP-10L..............................................................................................9
技术规格 特征及可选项 ................................................................................................................................................10
工作参数 .........................................................................................................................................................11
传动油规格 ....................................................................................................................................................11
效率曲线 , BDU-06S, 10S ............................................................................................................................12
效率曲线 , BDU-10L/21L, 21H, BDP-10L ...............................................................................................1
工作参数 概况 ...................................................................................................................................................................14
输入速度 .........................................................................................................................................................14
系统压力 .........................................................................................................................................................14
补油压力 .........................................................................................................................................................15
补油入口压力 ................................................................................................................................................15
壳体压力 .........................................................................................................................................................15
液压油 ..............................................................................................................................................................15
温度及粘度 ....................................................................................................................................................16
系统设计参数 液压油及过滤器 ...........................................................................................................................................17
油箱 ...................................................................................................................................................................17
控制轴作用力 ................................................................................................................................................17
独立刹车系统 ................................................................................................................................................17
主轴负载 .........................................................................................................................................................18
特征及可选项 轴选项 ..............................................................................................................................................................19
旁通阀 ..............................................................................................................................................................21
高压溢流阀(HPRV)及补油单向阀 (过压保护) ..................................................................................21
带阻尼孔补油单向阀 .................................................................................................................................22
可选集成油箱 ................................................................................................................................................24
过滤器 ..............................................................................................................................................................24
风扇 ...................................................................................................................................................................24
萨奥 丹弗斯BD系列静液传动单元.pdf
2010-1-27 20:05 上传
点击文件名下载附件
下载积分: 威望 -8 点
1.46 MB, 下载次数: 35, 下载积分: 威望 -8 点
