手板制作在各个领域的应用
查看: 238|回复: 9
发表于 2013-10-31 22:24:22 | 显示全部楼层 |阅读模式
一、在家电领域的应用:快速成型技术在航天事业中突出了它的优点,然而与航天事业想比,在国内家电事业中,快速成型技术的应用更为广泛,利用这种技术生产的家电不计其数。如今有很多知名的企业,利用快速成型技术使他们走到了家电企业的最前端,如众所周知的美的,海尔等品牌,这些知名企业,都是用快速成型技术来生产自己的产品,利用这种技术生产的产品,得到了很多消费者的信赖,快速成型技术性能优越,可以快速定型产品,并且开发出来。
二、在农业生产中的应用:农业机械生产过程具有特殊性。零件多具有较复杂的形状,如耕地机械、整地机械和收获机械等。此外,复杂曲面较多,如犁体曲面、旋耕机旋刀、水泵叶轮和送料螺旋等,而且根据具体的生产情况不同,其形状还需相应调整。因此,利用传统的机械加工方法研制这种农业机械零件,不仅研制开发时间长,加工工艺复杂,而且很难达到理想的效果。运用先进的激光快速成型集成技术,不仅大大缩短新产品的开发周期,降低开发成本,而且制造质量也优于传统制造方法。
三、在艺术领域的应用:在现在生活中,随着人类对精神文明追求越来越高,很多的家庭都会购买一些家居用品来装修居室,像名人字画,古懂,艺术雕塑品等。那么这些装饰品是如何制作出来的,如果采用纯手工,稍有不慎,就会造成缺陷,所以就要求艺术设计者小心翼翼,因此,手工制作所消耗的时间就很多,生产效率很低,满足不了市场的需求。
发表于 2013-10-31 22:25:06 | 显示全部楼层
很厉害啊,同志们
 楼主| 发表于 2013-10-31 22:26:01 | 显示全部楼层
Rapid Prototyping
The introduction of solid modeling made possible a new industry called Rapid Prototyping (RP), Additive Manufacture (AM), Solid Freeform Fabrication (SFF), or Additive Fabrication (AF). Rapid prototyping refers to the creation of physical models directly from an electronic part file using an additive process. That is, the model is created by building it layer by layer rather than starting with a block and then removing material to create the finished shape.
The first commercial RP method to be introduced was stereo lithography in 1987. In brief, this process, a photopolymer, a liquid resin that cures under the application of certain wavelengths of light, is cured layer by layer by a precisely guided laser beam.
In the early 1990’s, many new RP processes were commercialized. Among the most important was Selective Laser Sintering (SLS). In this process, plastic powder is sintered, or fused together, by the heat from a precisely guided laser beam.
Another process that achieved commercial success was Fused Deposition Modeling (FDM). The FDM process can be thought of as precisely directing a fine hot glue-gun to build up a part. The thermoplastic is usually ABS which is fed from a spool.
When RP was introduced, the available materials had low strength and were extremely brittle. As a result, the only practical application of RP was to produce visual aids. This use was important, since the effective communication of complex designs can minimize errors in their interpretation.
One of main concerns in the application of RP is the overwhelming cost that is attached to it. The systems that have been mentioned above can easily touch the £70’000 mark and then go onto reach £450’000. When the cost of maintenance, materials and an operator are added even a small model can be a couple of hundred pounds.
Also even though it has Rapid in the title, it can still take a couple of hours for the finished model to materialize, there is no means possible to make a fully functioned model within the hour, if it is to be of a high quality and good finish.
Most RP machines accept as an input a file called a stereo lithography (.sty) file. The structure of a .sty file is simple. The surfaces of the solid model are broken down into triangles, the simplest planar area. Each triangle is defined by four parameters: the coordinates of each of the three corners, and a normal vector that points away from the part, identifying which of the two faces of the triangle represents the outer surface of the part.
 楼主| 发表于 2013-10-31 22:26:57 | 显示全部楼层
常用CNC手板系统原理介绍
到目前为止.已有十几种不同的CNC手板系统问世.   其中比较典型的商品化HP系统有:分层物体制造(111m)、选择性徽光烧结(SS).立体平板印刷设备(SLA)‘熔积成型(FiMI)等、目前.生产z系统的主要制造商有关冈的Heliyys公司、新加坡的KINFR-GY公司。日本的[LIRA公司以及国内的清华大学,华中科技大学等;生产SLS系统的主要制造商有美fb的Ih公司.德网的FDS公司以及国内的北京隆舔快速成里有限公司、华中科技大学等;生产FUb1系统的主要制造商有关国的rlmy。公司及国内的济华大学等;生产S以系统的主要树造商有美国的3D Symmy.%公司.德闰的以公司以及国内的西安交通大学等。   切M的层面信息通过每一层的轮邢来表示,激光扫描器动作由这些伦廓信息控刹、它采用的材料是具有草度信息的片材、这仲加工方法只需要加工枪琳信息.所以可以达到很离的加工速度。但村料范困很窄.每层厚度不可调整是其最大的缺点,SU池用固体扮未材料。该材料在傲光的照射下.吸收能量.发生馆融固化.从而完成层谊息的成型,这种方法的材料适用范田很广。特别是在赶属和内瓷村抖的成型方面有独特的比点。似是所成型的零件精度和表面粗悦度较差,有待千进一步的提高,SLA快速成型技术使用的眨可光固化的液体材料。当扫描器在计算机的控zl下将激光器的能世按分层信息传递给成璧液面后、扫描区就发生聚合反应和因化,完成一层的加工。SLA快速成型所用激光器的激光彼长有限制.    一般采用UV lkC4激光器(32 mn)和UV Argou Ion滋光器(Mon. 364nm).采用这种方法成型的零件有较高的精度且表面光洁.但可用村料的范困较窄,FDH不是来用激光作能豫.而是将电能传递给塑料丝.在挤出喷头筋达列熔触状态,喷头在计算机的控剐下将熔触的塑料丝写到工作平台上.从而完成整个零件的手板加工过程。这种方法的能至传精和材料传粕均不同于前面的三种方法.系统成本较低.
 楼主| 发表于 2013-10-31 22:27:34 | 显示全部楼层
深圳凯福精密制造,为大家提供的不只是产品,更多的是服务。专业的技术,高效的管理流程和报价流程是我们最大的优势。就拿毕业设计建模来说,如果你是我们的客户,你给了我们你的设计图纸,我们不仅会给您一些更好的设计意见,同时保证在一个小时之内给您报价。让您体验快速高效的服务。还为您提供保密服务,您可以放心大胆的将设计交给我们,让我们为您制作完美的毕业设计模型。同我们合作过的客户,都愿意再次和我们合作,那是因为我们的产品质量好,而且服务更好。
在凯福做事:认真,负责,细致,尽职。在凯福做人:谦逊,好学,勤奋,诚信。因为这些,我们才赢得了更多的客户的尊重和信赖。我们秉承“专业、优质、高效、诚信”的精神,以“质量保证、价格合理、交货及时、服务至上”为原则,经过多年的开拓进取,已发展成为集塑胶、五金手板、小批量加工、产品抄数,外观、结构设计等为一体的专业手板模型企业。
总之,对客户的诚信,对产品的服务是任何企业都不可以轻视的,通过良好的诚信和优质的服务,建立起更好,更广,更深的关系,也是我们凯福人共同的心声和承诺!
 楼主| 发表于 2013-10-31 22:28:28 | 显示全部楼层
手板行业对设备的基本要求
与其他机械加工相比,手板加工有其一定的特殊性,这些特殊性主要是:
1.
大多数手板需要在实芯金属模块上加工出形状复杂的空间曲面,随着手板不断向大型化发展,模块重量也将越来越大,现在有的已达几十吨;
2.
大多数手板外形为长方体或正方体,很少有窄长形的,主要加工量集中在凹模和凸模上;
3.
随着手板制品要求越来越精密、复杂,对手板加工精度的要求也越来越高,现在许多手板的加工精度已达±1~2μm,不久将很快发展为小于±1μm;
4.
随着用户对手板生产周期的要求越来越短,手板加工就要满足高效、快速,且有一定柔性和长时间满负荷不停顿运行等要求。
根据上述4条特殊性,就对手板加工设备提出了如下一些基本要求:
1.
机床要有好的刚性和与模块重量相适应的大承载能力;
2.
工作台面尺寸要与手板外形尺寸相适应,宜于长方形或正方形及圆形,不宜窄长,而高度方向及其行程却要求有较大空间;
3.
要有高的精度及精度保持性;
4.
要能快速高效地去除余量,且有很高的可靠性,以保持连续长久满负荷运行;
5.
为适应复杂的空间曲面加工,且有大量的加工量,因此要求机床能多轴联动,且配有大信息容量的数控系统。
上面只提出了一些大多数手板加工对设备的基本要求,此外尚有不少特殊要求。例如加工塑料的机床就要求有更高的速度,但由于切削力小,为降低成本,机床可采用轻型结构;试模用的研配压机则不要求其高效快速,但要求有反转动能以便修模;某些简单工序的大量重复加工可用专机等等。同时,复合加工、柔性加工和在线检测也是手板加工的要求。
 楼主| 发表于 2013-10-31 22:29:07 | 显示全部楼层
CNC
批量加工
发展趋势
高速高精高效化速度、精度和效率是机械制造技术的关键性能指标。由于采用了高速CPU芯片、RISC芯片、多CPU控制系统以及带高分辨率绝对式检测元件的交流数字伺服系统,同时采取了改善机床动态、静态特性等有效措施,机床的高速高精高效化已大大提高。
凯福精密制造
今年新进了3台进口高速度、高精度的CNC加工设备,拥有CNC高速精雕机4台、CNC高精度加工中心2台、CNC车床2台;拥有车铣、火花、线割、真空复模等各类快速模具加工成型设备,完全贴合CNC批量加工的趋势---高速度、高精度,为客户做出满意的产品。柔性化 包含两方面:数控系统本身的柔性,数控系统采用模块化设计,功能覆盖面大,可裁剪性强,便于满足不同用户的需求;群控系统的柔性,同一群控系统能依据不同生产流程的要求,使物料流和信息流自动进行动态调整,从而最大限度地发挥群控系统的效能。工艺复合性和多轴化 以减少工序、辅助时间为主要目的的复合加工,正朝着多轴、多系列控制功能方向发展。数控机床的工艺复合化是指工件在一台机床上一次装夹后,通过自动换刀、旋转主轴头或转台等各种措施,完成多工序、多表面的复合加工。
凯福
公司用精密的加工设备,精湛的加工技术,为每一个客户服务。在
CNC批量加工
方面,能够加工各种复杂多变的形状,提高了在高科技制造中的应用。实时智能化 早期的实时系统通常针对相对简单的理想环境(environment),其运用是如何调度任务,以确保任务在规定期限内完成。科学技术发展到今天,实时系统和人工智能相互结合,人工智能正向着具有实时响应的、更现实的领域发展,而实时系统也朝着具有智能行为的、更加复杂的应用发展,由此产生了实时智能控制这一新的领域。
凯福精密
拥有SLA激光快速成型机等专业快速成型高科技设备,能够对产品或者图形进行专业复模,更高效快捷的对各类产品的进行制作,在
手板模型
、专业复模具有丰富的经验及专业的水准。
 楼主| 发表于 2013-10-31 22:29:58 | 显示全部楼层
快速成型基本知识
SLA快速成型(RP)技术是九十年代发展起来的一项先进制造技术,是为制造业企业新产品开发服务的一项关键共性技术, 对促进企业产品创新、缩短新产品开发周期、提高产品竞争力有积极的推动作用。自该技术问世以来,已经在发达国家的制造业中得到了广泛应用,并由此产生一个新兴的技术领域。 快速原型制造技术,又叫快速成形技术,简称RP技术);英文:RAPID PROTOTYPING(简称RP技术),或 RAPID PROTOTYPING MANUFACTURING,简称RPM。在汽车应用行业家RP样件。RP技术是在现代CAD/CAM技术、激光技术、计算机数控技术、精密伺服驱动技术以及新材料技术的基础上集成发展起来的。不同种类的快速成型系统因所用成形材料不同,成形原理和系统特点也各有不同。但是,其基本原理都是一样的,那就是"分层制造,逐层叠加", 类似于数学上的积分过程。形象地讲,快速成形系统就像是一台"立体打印机"。 RP技术优越性  它可以在无需准备任何模具、刀具和工装卡具的情况下,直接接受产品设计(CAD)数据,快速制造出新产品的样件、模具或模型。因此,RP技术的推广应用可以大大缩短新产品开发周期、降低开发成本、提高开发质量。由传统的"去除法"到今天的"增长法",由有模制造到无模制造,这就是RP技术对制造业产生的**性意义。 RP技术特点  RP技术将一个实体的复杂的三维加工离散成一系列层片的加工,大大降低了加工难度,具有如下特点:(1)成型全过程的快速性,适合现代激烈的产品市场;(2)可以制造任意复杂形状的三维实体;(3)用CAD模型直接驱动,实现设计与制造高度一体化,其直观性和易改性为产品的完美设计提供了优良的设计环境;(4)成型过程无需专用夹具、模具、刀具,既节省了费用,又缩短了制作周期。(5)技术的高度集成性,既是现代科学技术发展的必然产物,也是对它们的综合应用,带有鲜明的高新技术 特征。以上特点决定了RP技术主要适合于新产品开发,快速单件及小批量零件制造,复杂形状零件的制造,模具与模型设计与制造,也适合于难加工材料的制造,外形设计检查,装配检验和快速反求工程等。
 楼主| 发表于 2013-10-31 22:30:34 | 显示全部楼层
制造业的服务同样的很重要。服务是我们的第三产业,如今服务行业的整体发展是越来越好,但这里面也鱼龙混杂。很多产品的售后服务很差。使得消费者越来越少。最终产品滞销。所以更多的我们买卖的不是产品,而是服务。作为消费者,花了钱,却没有享受到服务,肯定是不行的。当下有多少公司可以拍着胸膛向大家保证产品质量,售后服务呢!我想:一个公司,一个企业,没有完善的服务体系,也是不行的。
深圳凯福精密制造
毕业设计建模
毕业设计
模型
集塑胶、五金手板、小批量加工、产品抄数
,外观、结构设计等为一体的
专业手板模型企业
凯福
人共同的心声和承诺!
 楼主| 发表于 2013-10-31 22:31:07 | 显示全部楼层
批量加工也分为大批量加工和小批量加工。大批量加工通常是以万计的,产品需要开模。而小批量加工从个位到三位数不等,是通过简易模,软模,或者直接加工出来的。小批量加工一般是车、铣、刨、磨、钳等通常的机械加工过程,钳工的下料、画线、打孔、攻丝等。大批量的加工就要开模具:比如塑料模具、压铸模具、冷冲压模具等。做工装:比如铣夹具、磨夹具、车夹具、钳工用的钻夹具等专用的夹具。总之,他们的加工的效率大大的不同。
为客户提供批量加工服务的工厂多如牛毛,那么为客户提供小批量加工服务的工厂又有多少呢?
深圳凯福精密制造
就是其中之一。凯福聚焦于CNC加工领域精湛加工技术,巩固公司在CNC手板模型方面长期积累下来的优势,大力提高公司在CNC精密小批量加工方面的能力,以最可靠的品质和最周到的服务赢得客户最长久的信赖。凯福可承接各种材料、各种工艺、各个行业的手板模型加工制作及小批量加工。为客户提供常见的
塑胶件小批量加工
五金件小批量加工
,同时提供
工业非标加工
等服务。
了解了大批量加工和小批量加工,我们就能更好的找到为我们服务的工厂和公司了。经过10多年的发展,凯福精密制造缔造很多经典的案例传奇,代表客户有比亚迪、西门子、国家电网、哈工大等等,这些都见证了凯福精密在CNC加工,手板模型领域的资质,我们会不但的追求和提高,尽最大的努力给客户带来最优质和诚信的服务。
