为什么我用mastercam X4编的程序倒圆角成这样的?!
查看: 317|回复: 9
发表于 2013-10-31 22:15:30 | 显示全部楼层 |阅读模式
为什么我用mastercam X4编的程序倒圆角成这样的?!不是现实的R多少,而是现实的I和K。希望高手给予指导。谢谢。。。
G0 T0101
G18
G97 S275 M03
G0 G54 X132.478 Z0. M8
G99 G1 X73.4 F.25
G0 Z2.
X400.
Z200.
X169.117 Z2.7
G1 Z-132.744
X171.228 Z-133.8
X173.
G0 Z2.7
X165.234
G1 Z-130.803
X169.517 Z-132.944
G0 Z2.7
X161.351
G1 Z-128.861
X165.634 Z-131.003
G0 Z2.7
X157.468
G1 Z-126.955
G18 G3 X157.814 Z-127.093 I-.534 K-.846
G1 X161.751 Z-129.061
G0 Z2.7
X153.585
G1 Z-126.8
X156.4
G3 X157.814 Z-127.093 K-1.
G1 X157.868 Z-127.12
G0 Z2.7
X149.702
G1 Z-126.8
X153.985
G0 Z2.7
X145.819
G1 Z-87.137
X148.378 Z-102.466
Z-126.798
G2 X148.7 Z-126.8 I.161 K5.347
G1 X150.102
G0 Z2.7
X141.936
G1 Z-63.876
X146.219 Z-89.533
G0 Z2.7
X138.053
G1 Z-40.614
X142.336 Z-66.272
G0 Z2.7
X134.17
G1 Z-17.353
X138.453 Z-43.011
G0 Z2.7
X130.287
G1 Z-5.823
X132.207 Z-7.205
G3 X132.558 Z-7.692 I-.822 K-.57
G1 X134.57 Z-19.749
G0 Z2.7
X126.404
G1 Z-3.026
X130.687 Z-6.111
G0 Z2.7
X122.521
G1 Z-.23
X126.804 Z-3.314
G0 X400.
Z200.
M9
G28 U0. V0. W0. M05
T0100
M01
(TOOL - 3 OFFSET - 3)
(车刀 75INSERT - CNMG 12 04 08)
G0 T0303
G18
G97 S275 M03
G0 G54 X121.594 Z.362 M8
G1 X132.022 Z-7.148 F.25
G18 G3 X132.162 Z-7.343 I-.329 K-.228
G1 X147.861 Z-101.391
G3 X147.869 Z-101.491 I-1.196 K-.1
X146.947 Z-102.436 I-1.2
G1 X139.025 Z-105.531
G2 X137.604 Z-108.35 I5.239 K-2.819
G3 X137.6 Z-108.393 I-.4
G1 Z-121.05
G2 X149.5 Z-127. I5.95
G1 X156.537
G3 X158.234 Z-127.352 K-1.2
G1 X171.766 Z-134.117
G0 Z200.
X400.
M9
G28 U0. V0. W0. M05
T0300
M01
(TOOL - 94 OFFSET - 94)
(OD THREAD RIGHT- SMALLINSERT - R166.0G-16MM01-100)
G0 T9494
G18
M05
G0 G54 X153.358 Z0. M8
G92 X148.505 Z-110. R-9.16 E6.35
X147.864
X147.328
X146.857
X146.433
X146.044
X145.682
X145.343
X145.022
X144.717
X144.426
X144.146
X143.878
X143.619
X143.368
X143.168
X143.168
G0 X153.358
X400. Z0.
Z200.
M9
G28 U0. V0. W0.
T9400
M30
发表于 2013-10-31 22:16:18 | 显示全部楼层
这我还真不知道什么原因
发表于 2013-10-31 22:17:12 | 显示全部楼层
后处理的问题,改下后处理就好了!
发表于 2013-10-31 22:17:53 | 显示全部楼层
是的后置处理没有修改好加我QQ335998297
发表于 2013-10-31 22:18:51 | 显示全部楼层
{:soso_e100:}后处理的问题 但是不需要修改后处理 在这里修改
这样安全可靠,后处理不要乱动,否则会出问题
 楼主| 发表于 2013-10-31 22:19:36 | 显示全部楼层
这样安全可靠,后处理不要乱动,否则会出 ...
你好,我找到自定义控制器了。应该改哪个?我都是过了怎么最后的程序还是I和K?
发表于 2013-10-31 22:20:14 | 显示全部楼层
I.J.K编程一样用,后处理改不好就就郁闷啦
发表于 2013-10-31 22:21:11 | 显示全部楼层
太乱了。。。有图纸就好了、、、、
发表于 2013-10-31 22:21:57 | 显示全部楼层
谢谢啦,很好的东东
发表于 2013-10-31 22:22:46 | 显示全部楼层
还是不习惯一段段读程序,下次麻烦把图上来好么?
