楼主 |
发表于 2013-10-31 21:55:20
O9730(REN PRINT);
(40120520 . OEB);
POPEN;
IF[#121NE#0]GOTO1;
#121=1;
N1;
IF[#122NE#0]GOTO2;
#122=1;
N2;
IF[#23NE2]GOTO3;
#121=#121+1;
#122=1;
N3;
DPRNT[ ];
DPRNT[----------------];
DPRNT[***COMPONENT*NO*#121[60]****FEATURE*NO*#122[40]];
#122=#122+1;
IF[#20EQ#0]GOTO4;
DPRNT[TOOL *OFFSET*H#20[40]];
N4;
IF[#19EQ#0]GOTO20;
DPRNT[WORK *OFFSET*S#19[30]];
N20;
IF[#18EQ#0]GOTO30;
(PCD INPUT);
#28=#135-#24+#4;
#29=#136-#25+#5;
DPRNT[PCD*FEATURE*NO*#147[30]];
DPRNT[INC*X#4[44]****ACTUAL*#128[44]];
DPRNT[INC*Y#5[44]***ACTUAL*#29[44]];
DPRNT[PCD*#18[44]***ACTUAL*#137[44]***DEV*#142[34]];
DPRNT[ANG*#1[44]***ACTUAL*#139[44]***DEV*#144[34]];
DPRNT[];
#1=#0;
N30(D INPUT);
IF[#7EQ#0]GOTO40;
IF[#8EQ2]GOTO31;
IF[#11NE#0]GOTO31;
IF[#20NE#0]GOTO31;
GOTO35;
N31(SIZE DATA);
#14=1;
IF[#11NE#0]GOTO32;
DPRNT[SIZE*D#7[44]***ACTUAL*#138[44]***DEV*#143[34]];
GOTO40;
N32;
DPRNT[SIZE*D#7[44]***ACTUAL*#138[44]***TOL*#11[24]**DEV*#143[34]];
IF[ABS[#143]LE#11]GOTO40;
#32=40;
GOTO110;
N35(POS);
IF[#13NE#0]GOTO36;
DPRNT[POSN*R#7[44]***ACTUAL*#138[44]***DEV*#143[34]];
GOTO40;
N36;
DPRNT[POSN*R#7[44]***ACTUAL*#138[44]***TOL*TP*#13[24]**DEV*#143[34]];
N40(X INPUT);
IF[#24EQ#0]GOTO50;
IF[#14EQ1]GOTO45;
IF[#11NE#0]GOTO41;
IF[#20NE#0]GOTO41;
GOTO45;
N41(SIZE DATA);
#14=1;
IF[#11NE#0]GOTO42;
DPRNT[SIZE*X#24[44]***ACTUAL*#138[44]***DEV*#143[34]];
GOTO50;
N42;
DPRNT[SIZE*X#24[44]***ACTUAL*#138[44]***TOL*#11[24]**DEV*#143[34]];
IF[ABS[#143]LE[#11]]GOTO50;
#32=50;
GOTO110;
N45(POS);
IF[#13NE#0]GOTO46;
DPRNT[POSN*X#24[44]***ACTUAL*#135[44]***DEV*#140[34]];
GOTO50;
N46;
DPRNT[POSN*X#24[44]***ACTUAL*#135[44]***TOL*TP*#13[24]**DEV*#140[34]];
N50(Y INPUT);
IF[#25EQ#0]GOTO60;
IF[#14EQ1]GOTO55;
IF[#11NE#0]GOTO51;
IF[#20NE#0]GOTO51;
GOTO55;
N51(SIZE DATA);
#14=1;
IF[#11NE#0]GOTO52;
DPRNT[SIZE*Y#25[44]***ACTUAL*#138[44]***DEV*#143[34]];
GOTO60;
N52;
DPRNT[SIZE*Y#25[44]***ACTUAL*#138[44]***TOL*#11[24]**DEV*#143[34]];
IF[ABS[#143]LE#11]GOTO60;
#32=60;
GOTO110;
N55(POS);
IF[#13NE#0]GOTO56;
DPRNT[POSN*Y#25[44]***ACTUAL*#136[44]***DEV*#141[34]];
GOTO60;
N56;
DPRNT[POSN*Y#25[44]***ACTUAL*#136[44]***TOL*TP*#13[24]**DEV*#141[34]];
N60(Z INPUT);
IF[#26EQ#0]GOTO67;
IF[#14EQ1]GOTO65;
IF[#11NE#0]GOTO61;
IF[#20NE#0]GOTO61;
GOTO65;
N61(SIZE DATA);
#14=1;
IF[#11NE#0]GOTO62;
DPRNT[SIZE*Z#26[44]***ACTUAL*#138[44]***DEV*#143[34]];
GOTO70;
N62;
DPRNT[SIZE*Z#26[44]***ACTUAL*#138[44]***TOL*#11[24]**DEV*#143[34]];
IF[ABS[#143]LE#11]GOTO70;
#32=70;
GOTO110;
N65(POS);
IF[#13NE#0]GOTO66;
DPRNT[POSN*Z#26[44]***ACTUAL*#137[44]***DEV*#142[34]];
GOTO70;
N66;
DPRNT[POSN*Z#26[44]***ACTUAL*#137[44]***TOL*TP*#13[24]**DEV*#142[34]];
N67;
IF[#13EQ#0]GOTO70;
IF[ABS[#145]LE[#13/2]]GOTO70;
#32=70;
GOTO120;
N70(ANG INPUT);
IF[#1EQ#0]GOTO80;
IF[#17NE#0]GOTO71;
DPRNT[ANG*#1[44]***ACTUAL*#139[44]***TOL*#17[24]**DEV*#144[34]];
IF[ABS[#144]LE#17]GOTO80;
#28=#144;
#29=#17;
#32=80;
GOTO130;
N80;
IF[#2EQ#0]GOTO199;
(ANG2 INPUT);
IF[#3NE#0]GOTO81;
DPRNT[ANG*#2[44]***ACTUAL*#142[44]**DEV*#143[34]];
GOTO199;
N81;
DPRNT[ANG*#2[44]***ACTUAL*#142[44]***TOL*#3[24]**DEV*#143[34]];
IF[ABS[#143]LE#3]GOTO199;
#28=#143;
#29=#3;
#32=199;
GOTO130;
N110(SIZE TOL);
IF[#143LT0]GOTO111;
#31=#143-#11;
GOTO12;
N111;
#31=#143+#11;
N112;
DPRNT[ ];
DPRNT[*******++++++OUT*OF*TOL++++*ERROR*#31[34]];
DPRNT[ ];
GOTO#32;
N120(POS TOL);
IF[#15EQ1]GOTO#32;
#28=#145-#13/2;
DPRNT[ ];
DPRNT[******+++++OUT*OF*POS++++*ERROR*TP*#28[34]*RADIAL];
DPRNT[ ];
#15=1;
GOTO#32;
N130(ANG TOL);
IF[#28LT0]GOTO131;
#31=#28-#29;
GOTO132;
N131;
#31=#28+#29;
N32;
DPRNT[ ];
DPRNT[****++++++ANG*OUT*OF*TOL++++*ERROR*#31[34]];
DPRNT[ ];
GOTO#32;
N199;
PCLOS;
M99; |
