机床行业英汉
查看: 261|回复: 0
  • 签到天数: 158 天
    发表于 2013-7-22 13:25:10 | 显示全部楼层 |阅读模式
    3-Jaws indexing spacers三爪、分割工具头
      A.T.C.system加工中心机刀库
      Aluminum continuous melting & holding furnaces连续溶解保温炉
      Balancing equipment平衡设备
      Bayonet卡口
      Bearing fittings轴承配件
      Bearing processing equipment轴承加工机
      Bearings轴承
      Belt drive带传动
      Bending machines弯曲机
      Blades刀片
      Blades,saw锯片
      Bolts,screws & nuts螺栓,螺帽及螺丝
      Boring heads搪孔头
      Boring machines镗床
      Cable making tools造线机
      Casting,aluminium铸铝
      Casting,copper铸铜
      Casting,gray iron铸灰口铁
      Casting,malleable iron可锻铸铁
      Casting,other其他铸造
      Casting,steel铸钢
      Chain drive链传动
      Chain making tools造链机
      Chamfer machines倒角机
      Chucks夹盘
      Clamping/holding systems夹具/支持系统
      CNC bending presses电脑数控弯折机
      CNC boring machines电脑数控镗床
      CNC drilling machines电脑数控钻床
      CNC EDM wire-cutting machines电脑数控电火花线切削机
      CNC electric discharge machines电脑数控电火花机
      CNC engraving machines电脑数控雕刻机
      CNC grinding machines电脑数控磨床
      CNC lathes电脑数控车床
      CNC machine tool fittings电脑数控机床配件
      CNC milling machines电脑数控铣床
      CNC shearing machines电脑数控剪切机
      CNC toolings CNC刀杆
      CNC wire-cutting machines电脑数控线切削机
      Conveying chains输送链
      Coolers冷却机
      Coupling联轴器
      Crimping tools卷边工具
      Cutters刀具
      Cutting-off machines切断机
      Diamond cutters钻石刀具
      Dicing saws晶圆切割机
      Die casting dies压铸冲模
      Die casting machines压铸机
      Dies-progressive连续冲模
      Disposable toolholder bits舍弃式刀头
      Drawing machines拔丝机
      Drilling machines钻床
      Drilling machines bench钻床工作台
      Drilling machines,high-speed高速钻床
      Drilling machines,multi-spindle多轴钻床
      Drilling machines,radial摇臂钻床
      Drilling machines,vertical立式钻床
      drills钻头
      Electric discharge machines(EDM)电火花机
      Electric power tools电动刀具
      Engraving machines雕刻机
      Engraving machines,laser激光雕刻机
      Etching machines蚀刻机
      Finishing machines修整机
      Fixture夹具
      Forging dies锻模
      Forging,aluminium锻铝
      Forging,cold冷锻
      Forging,copper铜锻
      Forging,other其他锻造
      Forging,steel钢锻
      Foundry equipment铸造设备
      Gear cutting machines齿轮切削机
      Gears齿轮
    文章关键词:
