换向阀的知识
查看: 256|回复: 0
  • 签到天数: 158 天
    发表于 2013-4-12 15:31:51 | 显示全部楼层 |阅读模式
      换向阀主要包括电磁换向阀,手动换向阀,电液换向阀,四通换向阀,多路换向阀,气控换向阀,五联多路换向阀,二位二通换向阀等。手动换向阀是用手动杠杆操纵阀芯移位的方向控制阀。在液压系统中,它可控制油流方向,以改变执行元件的运动方向。手动换向阀的滑阀换向定位方式有钢球定位式和弹簧复位式二种结构。钢球定位式是当操纵手柄外力取消后,阀芯依靠钢球定位保持在换向位置。弹簧复位式是当操纵手柄外力取消后,弹簧使阀芯自动回复到初始位置。电磁换向阀是通过电气信号来改变液流方向的控制阀门,它可用来实现液压系统的卸载,顺序动作及油路换向。电磁换向阀主要用于工程机械、矿山机械、起重运输机械以及其它机械的液压系统中。
      direction change valve include electromagnetic direction change valve, manual direction change valve, call liquid direction change valve, four way direction change valve, multiplexed direction change valve, gas control direction change valve, five of multiplexed direction change valve, two spaces, such as two-direction change valve
      Manual is a manual lever manipulation direction change valve disc killer direction control valves. In the hydraulic system, it can control the oil flow direction, the implementation of components of the Movement to change direction. Manual direction change valve the slide-valve for a way to the positioning of spaces steel ball positioning-and-two types of spring-loaded structure. steel ball positioning of manipulation handle external forces when lifting, positioning steel ball disc rely on to maintain in-place. When the manipulation of spaces is a spring-loaded handle external forces cancellation, disc spring-loaded to automatically revert to the initial position. direction change valve electromagnetic signals through electrical control valves to change the direction of liquid flow, it can be used to achieve hydraulic unloading system, the order to move and change oil flow. Electromagnetic direction change valve mainly for engineering machinery, mining machinery, transport machinery and other mechanical lifting hydraulic system
    文章关键词: 换向阀
