电动阀的知识
查看: 181|回复: 0
  • 签到天数: 158 天
    发表于 2013-6-12 00:05:08 | 显示全部楼层 |阅读模式
      电动阀是以电动机作为启闭阀门的动力,用于比较大型的阀门,高级的电动阀,可以用于工艺上的流量控制。电动阀具备装配容易、故障率低以及符合业界自动化需求的优点,是业者较划算的选择。因为使用一般传统气动阀,免不了要有配管、电磁阀及压缩机等才能匹配,而电动阀是以马达驱动,安装简易省事,且电动阀安装配合工厂原有的自控线路即可,可节省其他成本支出。此外,以马达驱动方式开闭较平顺,无瞬间冲力过大的缺点,故障率可大幅降低,不少人都认为电动阀贵,使用成本高,其实不然,如果以整体计算,传统阀要加上许多配件及管路安装,价格并未占优势,反而要承担较多的保养费.所以电动阀的前景是比较广阔的。
      Electric valves open and close valves on the electric motors as a driving force for the larger valves, electric valves, the processes can be used to control the flow.Electric valves fitted with easy, low failure rate in the industry and the advantages of automation needs is more economical choice operators. Because of the use of general traditional pneumatic valves, inevitably a ticket pipes, and electromagnetic valves, compressors can match, and electrical devices are motor-driven, easy to install, and the installation of electrical devices with the original robotic factory line will be able to reduce other costs. In addition to motor-driven approach to turn more smoothly, without an excessive momentum shortcomings, failures can be substantially reduced rate, many people believe that your electric valves, the use of high cost, but in fact it is not, if a holistic basis, and many accessories to traditional valves and the installation of pipelines, the price is not dominant, Instead, they will assume more maintenance. Therefore, the prospects for electrical devices are relatively broad.
    文章关键词: 电动阀
