通用阀门的英汉术语对照
查看: 226|回复: 0
  • 签到天数: 158 天
    发表于 2013-3-4 10:23:00 | 显示全部楼层 |阅读模式
      Air valves空气阀门
      Angle Stop valves角式截止阀
      Angle Throttle Valves角式节流阀
      Angle Type Globe Valves门角式截止阀
      Ash valves排灰阀
      Aspirating valves吸(抽)气阀
      Auxiliary valves辅助(副)阀
      Balance valves平衡阀
      Bellows valves波纹管阀
      Blowdown valves泄料(放空,排污)阀
      Brake valves制动阀
      Butterfly Type Non-slam Check蝶式缓冲止回阀
      Butterfly Valves with Gear Actuator蜗轮传动蝶阀
      Buttwelding valves对焊连接阀
      Clamp valves对夹式阀门
      Cock二通
      Combination valves组合阀
      CQ Thread Ball Valves CQ螺纹球阀
      Culvert valves地下管道阀
      Deceleration valves减速阀
      Diaphragm Valves隔膜阀
      Decompression valves泄压阀
      Double Disc Flat Gate Valves双闸板平板闸阀
      Double Disk Parallel Gate Valves明杆平行式双闸板闸板
      Double Opening Exhaust Valves双口排气球
      Drainage valves排水阀
      Electric Actuated Stop Valves电动截止阀
      Electric Actuated Wedge Gate Valves电动楔式闸阀
      Electric Double Disk Parallel Gate Valves电动平行式双闸板闸板
      Emergeny Cut-off Valves紧急切断阀
      Exhaust valves排气阀
      Free Float Type Steam Trap浮球式疏水阀
      Flange Ball Valves法兰球阀
      Flange Gate Valves法兰闸阀
      Flange Globe Valves法兰截止阀
      Gauge Valves仪表阀
      Hand-operated valves手动阀
      Hard Seal Butterfly Valves金属密封碟阀
      High Temperature Pressure Power Station Gate Valves高温高压电站闸阀
      High Temperature Pressure Power Station Globe Valves高温高压电站截止阀
      Hydraulic relay valves液压继动阀
      Lift Check Valves升降式止回阀
      Limit valves限位阀Lining Ball Valves衬里球阀
      Lining Butterfly Valves衬里碟阀
      Lining Check Valves衬里止回阀
      Lining Cock衬里二通
      Lining Globe Valves衬里截止阀
      Lining T-Cock Valves衬里三通旋塞阀
      Liquid Indicator液位计
      LPG Pipe Fitting液化气管件
      Magnetic Co-operate Globe Valves磁耦合截止阀
      Magnetism Forle Pumps磁力泵
      Manual Oil Pumps Valves手摇油泵(阀)
      Meter Needle Type Globe Valves仪表针形截止阀
      Oblique Stop Valves直流式截止阀
      Parallel Slide Valves浆液阀
      Pintle valve针形阀
      Piping Centrifugal Pumps管道离心泵
      Plunger valves柱塞阀
      Pressure valve压力(増压)阀
      Piping Pumps管道泵
      Piping Safety Valves管道安全阀
      Plunger Globe Valves柱塞截止阀
      Quick Draining Valves快速排污阀
      Restrictor Valves过流阀(或节流阀)
      Safety Valves安全阀
      Screw Pumps螺杆泵
      Scum Gate Valves排渣闸阀
      Solenoid valves电磁阀
      Single Disc Flat Gate Valves单闸板平板闸阀
      Single Opening Exhaust Valves单口排气球
      Slurry Pumps泥浆泵
      Stop Valves截止阀
      Strainer过滤器
      Submerged Motor Pumps潜水电泵(排污泵)
      Swing Check Valves旋启式止回阀
      Tank Lorry Ball Valves槽车球阀
      T-Cock三通
      Thin Gate Valves薄型闸阀
      Throttle Valves节流阀
      Tiny Drag Slow Shut Check Valves微阻缓闭止回阀
      Triple (tee) valves三通阀
      Two-way valves二通阀
      Under Water Pumps液下泵
      Vacuum Pumps水力喷射器(真空泵)
      Vertical Lift Check Valves立式止回阀
      Wafer Check Valves对夹式止回阀
      Wafer plate valves对夹蝶板阀
      Wafer Type Butterfly Valves with Rubber Itning对夹式衬胶蝶阀
      Waste Valves排污箱(阀)
      Water Seal Gate Valves水封闸阀
      Wedge Gate Valves楔式闸阀
      Y Type and Cylinder Filters Y型筒型过滤器
    文章关键词: 阀门
