TA的每日心情 | 开心 2017-7-6 10:10 |
签到天数: 4 天 [LV.2]偶尔看看I
应用 | (钻, 铣, 磨, 雕刻)机床电主轴
| Applications
| Drilling, Milling, Grinding, Engraving
| 外壳夹装尺寸
| 60 mm
| Clamping diameter
| 60 mm
| 马达类型
| 3相异步高速电机
| Motor system
| 3 Phase asynchronous motor
| 转速范
| 3,000 – 50,000 min-1
| Speed range
| 3,000 - 50,000 rpm
| 额定电压
| 220 V
| Voltage
| 220 V
| 电流
| 最大 14 A
| Current
| max. 14 A
| 扭矩
| 最大 215 Ncm
| Torque
| max. 215 Ncm
| 频率
| 50 - 833 Hz
| Frequency
| 50 - 833 Hz
| 功率
| 最大 2,000 W
| Output power
| max. 2,000 W
| 重量
| 3.5 kg
| Weight
| 3.5 kg
| 轴承
| 3 x 钢球轴承, 油脂润滑
| Bearing system
| 3 x Steel, lifetime lubrication
| 防护等级
| IP 54/57
| Protection category
| IP 54/57
| 电机保护
| PTC - 130 °C
| Motor protection
| PTC - 130°C
| 安装位置
| Working position
| 负载方向
| 轴向 + 径向
| Load direction
| axial + radial
| 锥面跳动
| 通常1 µm
| Run-out (taper)
| [ 1 µm
| 刀具夹持范围
| Ø 0.5 – 7.0 mm (ER 11)
| Chuck clamping range
| Ø 0.5 - 7.0 mm (ER 11)
| 换刀方式
| 1 开口扳手 (SW 13)
| Tool change
| 1 open-end wrench (13 mm)
| 冷却系统
| 外夹具冷却
| Cooling system
| Cooling via clamping bracket
| 防水防尘措施
| 密封气0.8–1.0 bar(管径Ø 内/外 4/6 mm)
| Protected against dirt
and cooling lubricant
| Sealing air 0.8 - 1.0 bar
(hose Ø outer 4 mm)
| 外壳材料
| 不锈钢
| Housing material
| Stainless steel
| 推荐变频器
| e@syDrive® TV 4538,
EMERSON SKCD200220
| Inverter recommendation
| e@syDrive® TV 4538,
EMERSON SKCD200220
| 保留修改权
| Subject to change without notice
